Sx20 Multisite
clark white
Level 2
Level 2
Dears,
I have a MCU 5310 with 4 port SD and a SX20. SX20 when try to get participants in conference for 2 no's other SX20 and 1 no's Jabber windows it doesn't consult MCU for resources , why??? no active conferences are seen in MCU,
Is it so becz  my SX20 is installed with multisite licenses.
Please confirm.
6 Replies 6
Martin Koch
If you could tell us a bit more about your deployment. Sounds that you use CUCM or is it VCS+TMS?
Which versions do you run on, how is your setup/configuration, how do the calls look like and how do you initiate the conference call?
Dear Martin,
yes it is registered to CUCM by provisioning and version is TC6.1.1.7d7af15 and i am just dialing a desired extension>call from the SX20 remote control, For every user i repeat the process and they are automatically in conference,
Also how many numbers multisite licenses i have how can i know , becz i am able to add only 3 no's of participant and my sx20 is the 4th who is initiating the conference so what it will be called, as 4 users conference or 3 users conference???
Correct number of users are 3+self, which equals 4, hence it's a "4 users conference".
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Dear Wayne and Jens
Thanks for the reply,
so wayne according to your reply there will be total of 7 participants in the conference if we do the combination.
thanks
Yes, there could be up to 7, but it isn't going to look pretty.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
The dialing process you're describing is using the MultiSite licence on the SX20, and not using your MCU.  As Jens has indicated, this will allow yourself + 3 = 4 total participants.
To use your MCU, you'd need either all of your participants to dial the MCU's conference number for the conference you're joining, or have the MCU dial out to all the participants.
Given that your MCU is only licenced for 4 participants, that may not help, so you might need to do a combination of the two- ie, use the MCU to dial 3 participants + your SX20, then dial the others (up to 3 more) from your SX20.
The resulting layout may look a bit funky though.  Your best bet would be to licence your MCU for the number of participants you want.
Wayne
Wayne
