SX20 \ MX200 standalone H.323 ports
Hi Guys,
topic is pretty explicative, i'm looking for a detailed list of TCP\UDP ports (inbound\outbound) that need to be opened on corporate firewall to let MX200 and SX20 work standalone. So far i have found details for C-Series:
: Gatekeeper Discovery (RAS)    Port 1719    UDP
  • Q.931 call Setup    Port 1720    TCP
  • H.245(Static)    Port Range 5555-6555    TCP
  • Video*    Port Range 2326-2485    UDP
  • Audio*    Port Range 2326-2485    UDP
  • Data/FECC    Port Range    2326-2485    UDP
Even if not specified, i assume these are inbound ports ( WAN -> LAN) , having "ANY" for outbound ports (LAN -> WAN).
Does anybody have a some sort of "magic table" i can use?
Thanks for you precious help.
Dan
9 Replies 9
Patrick Sparkman
C-Series port information I believe would apply for the SX and MX series, they both utilize either a C-Series codec or a flavor of it.
Hi Team
I have configure mx200 standalone h323 services but I'm getting fake unwanted call on my endpoint screen.How can I prevent this ? Is there anyway ?
You can turn off SIP under NetworkServices, but there will still be some calls that might come across as H323.
Putting it behind your firewall and restricting incoming traffic from known IPs that you want to conference with is really the only option to completely stop toll fraud calls.  Giving the endpoint a public IP address is not recommended as it makes it vulnerable to attackers and those trying to use it for toll fraud.
If you search the forums for "unwanted calls", you'll find many discussions regarding this and possible solutions.
Thanks Patrick , but It will not make tall fraud for my system because its only standalone system there is no  pbx and SBC  connected ITSP for sip &h323 services.
We did make static not private  mx300 ip to public ip on fw.
Thanks a lot.
There are systems out on the internet that are performing scans and probing for possible systems to exploit, they're scanning for the known open ports that could be used, and attempt a call when one is found.  Most of the calls will be over SIP, which is why I recommend you turn SIP off, but on occasion you might have a few trying H323 which there is no way to mitigate unless you restrict access on your firewall.
Tomonori Taniguchi
Port range is correct.
For H.323:
  • Gatekeeper Discovery (RAS): Port 1719 (UDP)
  • Q.931 call Setup: Port 1720 (TCP)
  • H.245(Static): Port Range 5555-6555 (TCP)
  • H.245(Dynamic): Port Range 11000-20999 (TCP)
  • Video*: Port Range 2326-2485 (UDP)
  • Audio*: Port Range 2326-2485 (UDP)
  • Data/FECC*: Port Range 2326-2485 (UDP)
         *Configurable by "RTP Ports Range Start" and "RTP Ports Range Stop"
Please note, restart Endpoint will require after modify Static/Dynamic port configuration before change affect.
Tomonori Taniguchi
This is bit difficult as H.245 negotiation port and RTP port is depend on far end device to specify.
If using 3rd party, these port range is different from Cisco Endpoint port range.
As Tomonori has stated, they are correct.
If you'd like a document that lists them all and some other port information, you could look at the following document.
Thanks Patrick & Tomonori,
with this recent endpoints galore was uncertain if changes were made on ports range!
