07-31-2017 11:13 AM - edited 03-18-2019 01:21 PM
We have 2 SX20s that having been running for years in the field. We brought them back to our data center to redeploy, and after doing a factory reset (to reset password), they are both now stuck in maint. mode. We have done the normal reboots, etc., but no luck. I have read a software upgrade might do the fix, but that seems odd since they were both working fine before the factory reset. Any ideas that don't involve an unnecessary software update?
Thanks!
Solved! Go to Solution.
07-31-2017 11:40 AM
Really, you're only options really are:
If none of the above doesn't bring the codec out of maintenance mode, suggest you contact TAC.
07-31-2017 11:40 AM
07-31-2017 01:22 PM
Ok, thanks Patrick.
