SX20
MARTIN DELANEY
Connecting to the API, according to API Reference Guide tc-7.2 can be done with a USB to RS-232 adapter to connect to the USB port.
I would appreciate feedback from anyone who has tested. (Can any of  usb ports be used)
Thanks ;-)
Hello Martin,
I´m currently using this configuration. What you need is a regular usb to RS-232 adaptader which you connect to you computer and on the codec side you need a null-modem cable or adapter that conects to the first one.
Make sure you set the baud rate to 38,400 and you are good to go
Alan
