SX80 & MX800 provisioning schema'
Nick Boylan
We have an SX80 and an MX800 on CE 8.2.2.
Looking at the provisioning schema's available the latest version I can get is 8.1.x. The description shows the download includes schema's for DX70, DX80, MX200G2, MX300G2, SX10, SX20 and SX80.
There is nothing for the MX800.
I imported the Schema for the SX80 into TMS and created a template but the provisioning doens't work.
Does anyone know where or how I can get the schema's for the MX800 and SX10 on CE version 8.2.2?
Thank you
I don’t know if it will work, but you might be able to change the system type in the below line:
<provisioningTemplate type="SX80" version="8.2.1">
Try changing it to MX800, or something similar.
Patrick Sparkman
Cisco hasn’t published any TMSPE schema templates since CE8.2.1, you could edit the XML file so it can support the larger MX endpoints. I recommend you contact TAC to see if they have any updated templates for CE software and if they officially support the MX700/800 endpoints.
Hi Patrick,
Thank you for your quick reply.
I'm looking at the XML for the SX80, do you know what parts I need to edit?
Thank you
Hi Patrick,
I've amended the line and its worked!!
Thank you  :-)
