10-03-2018 05:54 AM - edited 03-18-2019 02:23 PM
Hello ,
I have a sx80 with speaker track 60 integrate with a automate.
the touch 10 is used for launching calls not the crestron
the problem is that on the touch 10 the function Briefing room appears in gray because not active.
is there a way to disable the icon or feature on the tablet.
I did not find in the docs or the Forum if someone has the solution
thank you.
version sx80 ce9.2.3
Thierry
10-03-2018 08:35 PM
The icon for Briefing Room mode is grey - this doesn't mean it is disabled, that is its normal colour.
You can turn Briefing Room mode off completely by selecting the "Standard" Room Type in the web interface - see Setup > Room Types. This is mentioned briefly in the Admin Guide (see pages 72-77) in the section about setting up Brifing Room mode in the first place, which someone must have done on your endpoint.
Please remember to mark helpful responses and to set your question as answered if appropriate.
10-04-2018 01:15 AM
