10-26-2018 11:54 AM - edited 03-18-2019 02:25 PM
Is it possible to route PC audio using line 1 & 2 out to loudspeakers and route call audio to line out 3 & 4. I've successfully routed PC audio to 1 & 2 only and not our ceiling speakers, but call audio still comes out of the loudspeakers (1 & 2).
I am using WebEx Teams firmware dated October 10th, 2018.
Thanks for your assistance.
10-28-2018 11:06 PM
I can't remember if it's one of the things that is locked down when registering to the Webex Cloud or not, but, you can definitely do this on an on-prem registered device using the "Audio Console (beta)" that is included in CE9.5.0. (See Setup > Audio Console in the web interface of the endpoint).
With the Audio Console you can re-map inputs to outputs in the same way as you used to be abel to do on the old TC software versions with the TC-Console application, but now you are able to do it via the browser interface.
Please remember to mark helpful responses and to set your question as answered if appropriate.
10-29-2018 09:09 AM
Hi Wayne,
I've configured Audio Console so that the PC (Program) audio only feeds our loudspeakers in the room; however, I cannot find an option to stop call audio from coming out lines 1 & 2. Is it possible I need to repatch my overhead speakers so 1 & 2 are feeding them and 3 & 4 are feeding the loudspeakers? I've attached a screen grab from my current audio console setup.
Thanks for your time,
Patrick
10-29-2018 05:56 PM
If I've understood what you wanted correctly, you want the PC input to go out Line 1 and 2, and the rest of the audio to go out Line 3 and 4 (and the HDMI 1), so you would configure it similar to the attached screenshot.
