10-01-2003 08:58 PM - edited 03-17-2019 08:06 PM
i have a vg200 in 12.2(19) IOS. I try to enable tacacs+ authentication but it does not work.
Is there any sample configuration to turn on tacacs+ authentication for vg200.
10-07-2003 12:49 PM
The below configuration is sufficient
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login no_tacacs enable
aaa accounting exec default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
It is the same as configuring in other routers. Have a look at this link also
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t3/dt_aaara.htm
10-07-2003 09:48 PM
thanks for yr feedback. There is one command i cannot find in vg200. Tacaca-server host
without this command, tacacs+ cannot be used.
Do u knw whether vg200 can run tacacs+ ?
i appreciate yr feedback very much
