02-12-2011 05:47 AM - edited 03-17-2019 10:12 PM
Hi all,
I am planning to take the CCNP Voice certification by this year. But I am not sure that do I need to take the CCNA voice cert before take CCNP voice.
I am a CCNA certified 3 years ago and my cert is going to expire on this year May, 2011.
Can anyone advice on this?
02-12-2011 07:24 PM
Looks like you do need to have the CCNA Voice prior to starting the CCNP Voice: https://learningnetwork.cisco.com/message/127342
02-21-2011 08:17 AM
Hi Lim,
The CCNP Voice consists of 5 exams. You have to take all exams to complet ethe CCNP Voice.
If you sit for any of the 5 exams before the expiration date of CCNA, you'll be recertified in CCNA.
HTH!
Please rate.
02-25-2011 08:41 PM
Hi Lim,
You can take the CVOICE exam first and that will make you CCNA Voice, so then 4 additional tests to become CCNP Voice
Good luck
-Mario
