08-05-2004 05:18 AM - edited 03-17-2019 08:15 PM
How do you setup a Tandberg H323 Device as a H323 Client inside of CCM 4.0?
I have the 1000 setup to use CCM and gave its IP Address inside of the unit along with a internal extension as its E.164 number. Is there anything special that I have to do to get this to work with CCM.
In the Device name do I put what I put in the Tandberg as its E.164 Number?
First time trying this and really cannot find any good docs on it.
08-05-2004 05:38 AM
Got it! Should have waited just 1 more minute :-)
08-10-2004 12:36 PM
Brian
Would you mind posting what you did. I'm trying to do the same thing. TIA.
Larry
08-12-2004 12:15 AM
Sure,
I added a h323 client and for the device name "Make it the IP Address of the Tandberg Unit"
If you want Video and Audio without other H323 capabilities then DO NOT check use MTP resources. If you do you will get NO Video but Audio only but it still works. For the SCCP clients make sure you have in your DNS Scope
Default Router
DNS Server
Option 150
If you need a screen shot I can probably get that to you but by tommorow.
