11-23-2015 11:30 AM - edited 03-18-2019 05:14 AM
I work with videoconference management, including TMS.
Usually, when I want to see an endpoint camera transmition (and control the far end camera) I connect myself to the conference through TMS and watch it on Jabber.
My question: is it possible to watch instantly an endpoint camera transmition without using Jabber (through the endpoint browser console, for example)?
I'm asking this because in the browser overview there are only the arrows to control the camera, but there isn't any video transmition to check what you are controling (I'm sending an image of what I'm talking about).
Thanks for helping!
Lucas
Solved! Go to Solution.
11-23-2015 12:22 PM
You need to enable web snapshots, notice in the top right the two images that say "Web Snapshot Disabled". Whenever you enable web snapshots, you can then see the video being sent and recieved from the MXP. To enable web snapshots, you do so in Control Panel > Video, refer to the MXP Series Admin Guide on pg 63.
Note, you will only view web snapshots for non-encrypted conferences.
11-23-2015 11:36 AM
Hi Lucas,
Let me move this post to Telepresence community. This community is for Cisco Webex Meetings Server and Cisco Unified MeetingPlace products, and is not observed by TP experts.
I hope this will get you the answers you need faster.
Kind regards,
-Dejan
11-24-2015 05:21 AM
Ok, thanks!
11-23-2015 12:22 PM
11-24-2015 05:34 AM
I see. So it's not possible to watch a live video, only static images?
11-24-2015 07:20 AM
You could use the streaming function of the MXP to see live video, see Overview > Streaming. You can see the streaming tab in the image you uploaded.
11-24-2015 11:21 AM
I think it's the solution I'm looking for. My streaming in the browser is disabled, but I'll try configuring the endpoint to allow it. Thanks very much for your help!
11-23-2015 12:23 PM
The web snapshot is disabled so you cannot see the video on the web interface of the codec. You can only enable it by accessing the settings of the system using the remote control.
Using the remote control, go to Control Panel > Video and make sure web snapshot is enabled.
regards,
Acevirgil
11-24-2015 05:36 AM
Thanks!
