Tandberg - Video Conference Question
mfreshwater
Hello -
I was wondering if a Tandberg camera could video conference with a webcam and if so, how? Would there need to be a 3rd party software to connect the two? Here at our foundation to do a lot of video conferencing however the people on the other end don't always have that option so they resort to Skype via webcam. So, in this situation is there a way to connect their webcam to our Tandberg so that 3-6 people aren't trying to huddle around a tiny webcam and we can take advantage of our Tandberg?
Thank you in advance -
Matt
Jens Didriksen
Level 9
Level 9
You're not being vey clear as to what you want to do, "if a Tandberg camera could video conference with a webcam" doesn't make much sense at all.
Do want to connect your TANDBERG videoconferencing end-point to someone using desktop videoconferencing solution which uses a webcam, or do you want to connect a webcam to a TANDBERG system?
Or, do you want to connect using your TANDBERG, to someone who is nornally using Skype?
If so, then get them to install JabberVideo; https://www.ciscojabbervideo.com/home
Support:
https://supportforums.cisco.com/community/netpro/small-business/jabbervideosupport
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Ravi Yadav
Level 4
Level 4
Hi Matt,
I assume what you wish to know is if you can use your tandbrg camera to your desktop application the answer is no.
Is there a way you can intigrate your tandberg unit to be used as the video conf. Device on your desktop/laptop then that will also be a no.
Rest as mentioned by Jens cisco jabber can give you the interconnection between the two
Ravi kr.
Sent from Cisco Technical Support Android App
