Tandbert 880 - Anex O
Hola a todos los visitantes de esta discusión.
Mi plataforma de videoconferencias se conecta con sitios de internet utilizando un Polycom VBP-E.
Tengo la oportunidad de adquirir un Tandberg880, pero creo que este equipo no soporta llamadas marcando con el signo '#'. Los equipos Polycom y Huawei que tengo si soportan este tipo de marcación, ¿El equipo Tandberg880 soporta la marcación utilizando el signo '#'?
Desde ya muchas gracias a todos los que respondan.
Jens Didriksen
Level 9
Level 9
Apologies for not replying in Spanish, but my Spanish is not very good.
IP_address##Alias is proprietary format (not Annex O) and is not supported by TANDBERG/Cisco systems.
TANDBERG/Cisco systems supports Annex O which is Alias@domain (can also be Alias@IP_address).
I.e. Polycom dials 10.10.10.10##12345 - TANDBERG/Cisco dials 12345@mycompany.com or 12345@10.10.10.10
At least newer Polycom systems also supports Annex O and as far as I know, VBP can also be configured to support both forms of dialling.
/jens
Please rate replies and mark question as "answered" if applicable.
Please rate replies and mark question(s) as "answered" if applicable.
Jens Didriksen
Level 9
Level 9
/jens
Apologies for my bad english, I hope you can understand my ideas...
Thanks you very much for your detailed response, Jens. I didn't know that IP_address##Alias is a propietary format, I thougt that it is standar. I knew that Cisco doesn't sopport the '#' sign. I have tried dialing with @ througt the Polycom VBP and it works!
Thanks you again.
