Tanderg edge 95 MXP need I something else?
IngGerardo013
We have this device that shows the next leyend " Can not receive or make calls. Network option is not installed. Install bandwith option" Loking for options I found the next ones:
Table 3. Ordering Information
Product Name Part Number Compliance Model Number
Cisco TelePresence Edge 95 MXP CTS-EDGE95-K9 TTC7-14
Comes with: Edge MXP codec, 512 kbps ISDN/2 Mbps IP bandwidth, Natural Presenter Package, MultiSite, Cisco
TelePresence PrecisionHD Camera 720p, 1 microphone, remote control
Video Standard Options - Choose One
CTS-NTSC for Edge MXP CTS-NTSC
PAL Option for Edge MXP CTS-PAL
First of all, is this problem related to licences?... Someone can guide to me to know what is that option (in case of that was the problem) ?...
thank you so much
Hi Ing,
It seems to be some contractual issues, for which you need to open a TAC case due to the data integrity/security reason.
may be it will not be supported as per the current status however there are always alternatives.
I can give you an overview.
this device is not showing any contract ,and was unable to find any sales order number , probably you can provide that as you would have the purchase documents for this device.
you can reach to the accounts manager for your firm who manages the updation of the contracts as this
as of now there in only one key associated that is the product key and is installed to make it Edge 95
no other options generated
as i do not have the SO or PO number cannot check if there was any other option purchased ,
you can reach to the cisco sales centre for any further keys purchases , or your accounts team
Ravi Kr.
8 Replies 8
amehla
Hi Inggerardo,
are you trying to make IP -IP call or ISDN call ?
did you configured the system for same like, ip settings and ISDN settings ?
Hi Amit
We get to factory defaults, and the calls are IP-IP..
Licencing problem? or configuration problem?...
any input will be very apreciated
Open a telnet session and type xstatus systemunit and paste the result here.
"We get to factory defaults,"
Did you reset the unit to factory defaults? If so, all the option keys needs to re-installed.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Hi Jens,
this is the output showed:
xstatus system
*s SystemUnit:
     ProductType: "TANDBERG Codec"
     ProductId: "TANDBERG Edge 95MXP"
     Uptime: 1355
     Software:
       Version: "F9.1.1 PAL"
       ReleaseDate: "2011-09-28"
       CameraSoftwareID: "30038"
       Configuration:
         Telephony: 1
         VideoTelephony: 1
         TotalBandwidth: 0
         ISDNBandwidth: 0
         LANBandwidth: 0
         PresenterOption: False
         MultisiteOption: False
         StreamingSupport: True
         Encryption: True
     Hardware:
       SerialNumber: "26B16893"
       MainBoard: "101070 rev. 07"
       AdditionalBoard: ""
       BootSoftware: "Rev. 1.16, 2009-01-21"
       Configuration:
         PRI: 0
         BRI: 4
         ExternalNetwork: 0
         VGA: 1
         DataPorts: 1
         AudioInputs: 4
         Settop: False
         TV-Standard: PAL
     TemperatureCelcius: 42
     TemperatureFahrenheit: 107
*s/end
Hi Ing,
The device comes with the mentioned keys however you need to  install/update the keys on the codec when a new install or after a  factory reset you need to go to the system setting and put the bandwidth  option keys under bw option tab and you would be good to go as, with out any bandwidth key installed this device will not be able to make  any calls
this is a license configuration problem as it is not updated on the codec.
Hope this would resolve ur problem
Ravi kr
Go to www.cisco.com/go/license
Login with your CCO ID, then go to Get Existing > TANDBERG License
You should be able to put in the serial number and get the original release/option keys.
This is the email that we receive from Cisco:
You have received this email because your email address was provided to Cisco Systems during the Serial Number Lookup process for software license activation key/file.  Please read this email carefully and forward it with any attachments to the proper system administrator if you are not the correct person.
System Serial Number       : 26b16893
Hardware Serial Number     : 26b16893
MAC Address                : 00506083D8C6
Service Contract           : No Service Contract Found
SC End Date                : -
Software Part Name         : LIC-S50000-K9:
Tandberg Item No           : LIC-S50000-K9:SW PAL/NTSC for MXP
Shipped Version            : -
Shipped Version Key        : -
Shipped Image URL          : -
Options
Cisco Option Name       :L-EDG85TO95:
Tandberg Option Name    :L-EDG85TO95:Edge 95MXP product id
Option Key              :0366345623178166
and this is the screen when we are trying to configure:
Also, Cisco did not provide us the bandwith key, maybe because we do not have it, how can we know if device was purchased with this one?...
Hi Ing,
Ravi Kr.
