06-19-2014 01:17 PM - edited 03-18-2019 03:05 AM
I am pleased to announce that TC7.1.4 is released and can be downloaded on http://www.cisco.com.
Fixes bug CSCup25163 - Multiple Vulnerabilities in OpenSSL - June 2014
Includes the following OpenSSL vulnerabilities identified by the Common Vulnerability and Exposure (CVE) ID's:
CVE-2014-0224
CVE-2014-3470
Bug fix release.
Please read the release notes:
http://www.cisco.com/en/US/docs/telepresence/endpoint/software/tc7/release_notes/tc-software-release-notes-tc7.pdf
Magnus Ohm
06-20-2014 03:35 PM
Hello Magnus -
Have a question. Noticed the different TC software codecs, that although they all run TC software, select codecs have different software files. Such as SX10, SX20/MXG2, SX80 each all have different versions of the TC software filename from one another and from the other TC software codecs. Why the different file names of the same software, you guys have managed to have the same software C Series/EX and others?
Just asking, I'm getting an SX10 soon, and noticed this week that I'll need to make sure I download a different file from the other C Series/EX codecs.
06-21-2014 11:12 AM
This is because of the the different hardware platforms on the codecs so the software is the same but tweaked to support the different hardware platforms. This is why we need separate software packages. It is unfortunate but that is how it must be. Some systems are based on the same platform as SX20, MXG2 and SX80, MX700/800, C-Series/EX/MXG1. If you search for SX10 and get the download page of SX10 on Cisco.com you should automatically get the correct software package for this system.
/Magnus
06-21-2014 11:22 AM
That's what I figured, and it makes sense as the hardware evolves, different tweaks as you say would need to be made to the base software, hence different file names.
06-30-2014 12:38 AM
Hi Magnus,
I found that not only TC7.1.4, but also TC6.0.3 is described as Known Fixed Releases at https://tools.cisco.com/bugsearch/bug/CSCup25163.
Is this really correct?
Kotaro
06-30-2014 06:00 AM
06-30-2014 05:00 PM
Thank you Patrick,
So we need to downgrade from TC6.3.1 to TC6.0.3 if we want to use bug fixed TC6.x codecs?
We have just upgraded many codecs because of Heartbleed bug but now we have to downgrade them
Kotaro
06-30-2014 09:16 PM
Hi Kotaro,
It all depends on which bug sets you're trying to be free of... and which you consider to be more of an issue.
If you absolutely must stay with TC6.x then:
TC6.3.1 is the only version that's Heartbleed fixed (but doesn't include the other OpenSSL fixes)
TC6.0.3 fixes the other bugs listed above (but not Heartbleed). Note: TC6.0.x also includes quite a number of other bugs that have been resolved in the later versions (ie CVE-2013-3378)
If you want to go to a version that includes fixes for all of the above, you'll need to go to TC7.1.4.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
07-01-2014 12:14 AM
Thank you Wayne,
Then I will use TC7.1.4...
Anyway these OpenSSL bugs exusts me.
Kotaro
