TCS - Blackboard Integration
Patrick Sparkman
I see in product notes and other articles that TCS can have some sort of integration with Blackbaord.  Where can I find more information about this?  Has anyone attempted this type of integration?
Thanks! Patrick
antigles
Hi Patrick,
I think you might be referrig to Cisco TelePresence Sync.
On the following link you can find the list of supported devices http://www.cisco.com/en/US/docs/telepresence/endpoint/software/synch/synch_release_note_v3-20.pdf
Ant this is the product page http://www.cisco.com/en/US/products/ps11653/index.html
Best regards.
From some information I've gathered, I believe in order to accomplish this, you would use the TCS's API, and someone would have to develop the Blackboard part of it using that.
