TelePresence MX800 no luck making it operational
We have a Cisco MX800 teleprescense and we had no luck on making it operational
not much support from Cisco or partners
what can we do?
P/N 68-100272-02
S/N FCZ1913S04Q
Thank you,
David Martinez
Monty Bassiouni
Hi David, can you provide more clarification please? Feel free to contact me directly at monty.bassiouni@insight.com
I have done many Mx800s in the past and might be able to help
6 Replies 6
jtreu
It won’t register or ?
kennseto@cisco.com
Hey Dave, Unicast me in the Telepresence TAC - kennseto
luisalva777
What's the issue? Not registering, not booting?
Luis A.
saomoarelojie
What is the version of CUCM and MX800?
Monty Bassiouni
Wayne DeNardi
Hi @DAVIDMARTINEZ4870, are you able to provide a better description of "no luck making it operatonal" - is it working at all, or are you having issues registering it with you call control platform, or something else?
If it's just the installation and getting it to power up, make sure you have followed all the steps in the Install Guide and double check all your cables are connected correctly.
PS I have almost moved your discussion to the TelePresence section of the Cisco Community where these devices are discussed at a more technical level than the CCP forum you posted in.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
