TMS 13.2.2 and C40 Codecs with SW 6.1.0
matthiasflunker
Hello all,
I think I have a simple question.
Is it possible to administrate with an TMS 13.2.2. my new delivered C40 codecs with software release 6.1.0.
Thanks and best regards
Matthias Flunker
thobonho
Hi Matthias,
Short answer is "yes"!
Howerver, if you only have https enabled on the codecs and your TMS is installed on Windows Server 2003, make sure to install the following hotfix or you'll get "no http response" : http://support.microsoft.com/kb/948963
Supported cipher suites have been restricted in TC6.1.0 for security reason but Windows XP and 2003 don't support AES by default.
Hope that helps,
Thomas
thobonho
Hi Matthias,
Hope that helps,
Thomas
Hello Thomas,
thanks for your fast reaction and "yes" it helps.
Best regards
Matthias
