TMS 15 and MS SQL 2016 Compatibility
Nick Bochkaryov
Hi to All,
We are planning to upgrade our Cisco TMS  v.14 with Cisco TMS v.15.4 and locate databases on MS SQL 2016. Please advice if TMS v15.4 and TMSPE 1.9 were tested and compatible with SQL 2016?
Many Thanks in advance,
Nick
Patrick Sparkman
TMS 15.4 and TMSPE 1.9 does not yet support SQL Server 2016, it currently only supports up to version 2014.
Shefali Sharma
Hi Nick,
For now only SQL 2014 is supported for TMS. Plan for SQL 2016 server support will be most likely for future releases but not for the immediate release that is TMS 15.5.
Release Notes for TMS 15.5:
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tms/release_note/Cisco-TMS-release-notes-15-5.pdf
Cheers,
Shefali
