TMS backup question
rfrome
In TMS under Systems > Configuration Backup > Perform Backup, where is this data stored? I can see that it was successfully backed up, but where did it place the data?
Magnus Ohm
Hi, this data is stored in the tms database (TMSNG). Its not stored in a separate file. So in order to keep it safe, backup the database.
/Magnus
Magnus Ohm
/Magnus
What directory is it under on the TMS? And what format?
Hi Feby,
It is SQL database and you should use free MIcrosoft tool "Microsoft SQL Management studio" to create backup. Just install it on TMS.
Best Regards,
Artem Borodai
TMS just keeps on backup configuration of one system. It would be nice, if it could keep multiple configurations.
Regards, Paul
