TMS Basics
Hellu All,
Is there a way i can capture Debugs and logs (wireshark) On TMS.
Is there a Guide which wll tought me to schedule a confrence on TMS.
Please help
I thank u for reading.
Dorte..
Jens Didriksen
Level 9
Level 9
You might be able to find something of interest here:
http://www.youtube.com/results?search_query=cisco+tms&oq=cisco+tms&gs_l=youtube.12..0l2.3520.10044.0.12178.9.9.0.0.0.0.223.1309.4j0j5.9.0...0.0...1ac.1.11.youtube.7voQCeM3jhk
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Dorte,
All TMS related documentation can be found here, which will more than likely answer some or all of the questions you have:
http://www.cisco.com/en/US/partner/products/ps11338/tsd_products_support_series_home.html
I always recommend reading the latest and greatest release notes, TMS install and upgrade guides and especially the TMS Admin doc
rgds,
Dale
in addition to whats written above:
* tms is based on a windows server, so do a remote desktop session as admin to it and install and run wireshark on it, I use it all the time and it works fine
* again, as its windows based, check the event log and other typical places
* browse the tms folder for logs
* on the tms webinterface > admin tools > tms server maintanance you can download a set of tms logs
Please remember to rate helpful responses and identify helpful or correct answers.
