TMS error 403 : forbidden
smilewonee
When I click the button of log out, the message above comes out ( 403 error : forbidden )
what should I do for it?
I think there is incorrect configuration on authectification setting. However, I couldn't really find any practical solution.
Help me If you can!
Best wishes
Paul.
thobonho
thobonho
Hi Paul,
This is a known issue. Take a look here:
https://tools.cisco.com/bugsearch/bug/CSCuh08527
Thanks Thomas, problem solved!
jameskeagie
This solved our problem as well too.  Thanks for the informative drop of info!
