In terms of TMS exchange integration, what is the difference between LIC-TMS-APPINT and LIC-TMS-MSEX-25?
I've always used LIC-TMS-MSEX-25 deploying TMSXE and enabling 25 systems with the ability for remote booking.
Does LIC-TMS-APPINT use TMSXE in the same way but licenses all endpoints in TMS? therefore you don't have to tick the remote booking tab on the endpoint? Or is it deployed differently using developer API's?
Thanks, Simon
