Commissioning of a Webex Room Kit Pro without a Touch 10
MikeB48098
Newbie question:  Is it possible to configure/commission a Webex Room Kit Pro without a Touch10?  Obviously we can reach the Web page, but are the details that would normally be done on the Touch 10 accessible via browser?
5 Replies 5
Mike_Brezicky
If you are using a third party system like Crestron to control it, you should not need the Touch 10. You can go into the peripheral settings and set TocuhPanels to 0 and the system will not check for the Touch Panel.
Thanks... how can I enter the Registration details that the Codec needs to be activated (Pin code?) without the Touch 10? I haven't found a way to enter those details via the Web Page.
~Mike
Sorry... wrong terminology... Webex Cloud Key, not PIN code
I don't believe there is any way to enter the activation key other than the Touch 10.
I do not think there is a way. Checked the API guide as well and there is no remote option either. So you will at least need a Touch 10 for initial provisioning.
