TMS Login from remote application - log-web.txt question
marco_81
Hi all,
we are trying to login to TMS from remote application by means of GET and then POST HTTPS. TMS is running over IIS web service provided by MS server 2012.
This is a view of log-web.txt :
TMS Version 15.3.0 (IIS APPPOOL\TMSNet40AppPool)
2017-12-18 11:47:06,579 [132] ERROR ASP.global_asax -
Idunno.AntiCsrf.PotentialCsrfException: The CSRF cookie value did not match the CSRF parameter value. (Url: 'https://tms_ip_address/tms/auth/login.aspx?ReturnUrl=/tms/' QueryString: 'ReturnUrl=%2ftms%2f')
at Idunno.AntiCsrf.AntiCsrfModule.RaiseError(Exception ex, HttpContext context)
at Idunno.AntiCsrf.AntiCsrfModule.ValidateAntiCsrfToken(HttpContext context)
at System.Web.HttpApplication.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
2017-12-18 11:47:06,595 [132] ERROR Tandberg.TMS.UI.MasterPages.TMSMaster -
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.Collections.Generic.List`1.get_Item(Int32 index)
at Tandberg.TMS.Common.TMSMenu.SetActiveMenuItem(Int32 activeMenuItemId)
at Tandberg.TMS.Service.Navigation.NavigationService.BuildMenu()
at Tandberg.TMS.Service.Navigation.NavigationService.GetMenu()
at Tandberg.TMS.Service.Navigation.NavigationService.get_CurrentModuleId()
at Tandberg.TMS.UI.MasterPages.TMSMaster.IsTmsPePage()
2017-12-18 11:48:09,736 [139] ERROR ASP.global_asax -
2017-12-18 11:48:09,751 [139] ERROR Tandberg.TMS.UI.MasterPages.TMSMaster -
Does anybody faced with this error before?
best regards
Marco
8 Replies 8
Zac Colton
Please clarify what you are trying to accomplish. The TMS Portal is a web site, to be accessed from a web browser.
i hope my team will provide more information about this and then i would be able to reply.
marco_81
i have collected information about it.
We need to perform web authentication against TMS, to accomplish this we deployed javascript code executed on an application machine (with IP address: "Application IP" as per print screen attached), this java code simulate an interactive login against a form (such as typing username e password). That code performs HTTP Get first, and it retrieves  the html form login from TMS web server, then perform HTTP Post with username and password. We have compared results by performing manual\standard login to TMS, and automated by code login to TMS. The first case is attached as "standard login", second one "automated_login".
The differences between them are Referer and Oring header.
TMS_IP: stands for TMS's IP address, CUCM_IP stands for CallManager IP.
I still do not understand what you are trying to accomplish as a whole. What is the purpose of the web authentication?
The purpose is to login to a set of Cisco applications from a web portal without filling username\password every time i would access to the target resource. We are able to perform successful automatic login to Cucm, VCS, Conductor by the customized application, the only application with problem is TMS. Make sense?
CUCM, VCS, and Conductor all used forms based authentication. TMS, by default, does not. Authentication is done through and handles by IIS and the underlying operating system. The use of Integrated Windows Authentication will allow a client to access the TMS Portal pages without having to provide credentials manually. I am not sure is there are any publish documentation regarding enabling forms based authentication for TMS web application.
Thanks for reply, i will rate as helpful.
For our purposes we solved bypassing CSRF security check, i know it is a vulnerability but we needed to trigger a HTTP POST from another web site toward TMS, and as per CSRF security check, Origin header inside POST was the obstacle.
I suggest to not disable CSRF, but in our case we need it.
regards
We finally found issue on CSRF tokens managed by the remote web application. When the remote web application performs HTTP methods toward TMS (that is the target origin) , it has to send CSRF token too.
So CSRF security checks these two conditions:
- what is the domain the request came from (if it is different than the target origin just consider CORS and set Access-Control-Allow-Origin in the response to be equal to the Origin header set in the initial request)
- remote web application has to send CSRF token matching those originated by TMS\IIS.
Then we were able to enable antiCSRF again (never disable it).
In brief: "The CSRF cookie value did not match the CSRF parameter value" was related to a wrong behaviour of our remote app sending wrong CSRF tokens.
regards
