03-19-2015 04:26 PM - edited 03-18-2019 04:13 AM
at the moment I am setting up a new video infrastructure. All components have the lateste software.
- SX-Endpoints are registered to CUCM
- CUCM has SIP trunk to conductor
- Ad.Hoc and Rendezvous conferences are working
- TS is managed by Conductor
- SX-Endpoints, Conductor and TS have been added to TMS
Now the problem. I am setting up a new conference in TMS and automatically the conductor will be added. Now I start the conference and the conductor tries to call the endpoints and the call fails. I thought conductor uses the trunk for rendezvous in order to dial out to cucm. Inbound CSS on the CUCM site has been configured. Do I need anything special on the conductor or TS?
If you need logs or something else just let me know.
Daniel
03-19-2015 06:23 PM
I don't know anything about CUCM, but in the Conductor logs, do you see it trying to tell the TelePresence Server to dial out to the endpoints?
03-20-2015 12:48 AM
Hi Patrick,
on the Telepresence Server I see
And on conductor I see:
conferencefactory.controller: Level="INFO" Event="The SIP address of an out-dialed participant will be overridden on the target conference bridge if the bridge supports the 'toOverride' parameter." Auto-dial_participant_address="f997a3cd-e1d4-4abd-9649-a21d52a363e7@192.168.1.1:5073" toOverride_sip_address="1234@192.168.100.10" UTCTime="2015-03-19 23:15:01,532"
03-24-2015 01:31 PM
Daniel, I'm having the exact same issue. I followed the deployment guide to the the T. Everything works except for out-dialing. In my case I'm not using TMS scheduling yet (I will be soon), but I have an auto-dial participant configured. I see the same error in my conductor logs.
Mike
03-25-2015 07:57 AM
I found the solution. I had configured the SIP settings on TelePresence Server to use TCP instead of TLS. As soon as I changed the protocol, the calls worked fine.
04-09-2015 07:26 AM
Thanks Daniel for this hint.
I also had everything configured with TCP, as soon as I changed Outbound transport to TLS under Configuration, SIP settings, calls to Auto-dialed participants started working.
Thank you.
04-09-2015 08:42 AM
And my resolution also turned out to be the same. I had to get a TAC engineer involved to show me that I had missed that setting. Oh well. :)
