TMS upgrade from 14,5 to 15
devraj123
Hi All,
Do we need to  run any scripts (as mensioned in release notes for TMS 14.6.X ) or any other database manipulation or checks required on the TMSNG database before the upgrade from TMS version 14.5 to TMS version 15.0) for a large scale deployment of TMS.
Planning to move  to version 15.0 of Cisco TelePresence Management Suite.
No. of endpoints in TMS = approx 4700
DB size 50000 MB
Currect version- 14.5
Apprecitae your feedback
Deva
I have recently done this upgrade (from 14.5.0 15.0).  No additional scripts were required to be run before the upgrade.
Only thing to note was bug CSCuv40676.  You may need to manually purge some data from your database and disable automatic update checks.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Patrick Sparkman
Unless the TMS Install and Upgrade Guide specifically states that steps are needed to be taken before you upgrade from a previous version, you don't have to.
Wayne
Wayne
