TMS version 15.X compatibility matrix
Aman Soi
I need the compatibility matrix of TMS version 15 . X with endpoints models  and their firmware's [CE/TC] , SQL  , Phone books , Windows OS ,VCS and  ESXi details
I checked the below link. If somebody has for TMS15.7, 15.8,______ 15.10 , please share
https://community.cisco.com/t5/collaboration-voice-and-video/tms-versions-amp-features-matrix/ta-p/3329370
regds,
aman
JFerello
This is still a work in progress, I am updating it today.
Justin Ferello
There isn't a single document that shows what is supported in each and every version.  You are best off reading the TMS Release Notes to see what additional device support or WIndows/SQL requirements were added in that version (ie, TMS 15.10.0 added support for the latest Webex Desk Pro device which wasn't officially supported in earlier versions).
It's highly recommended that you run a current release of TMS and not an older one if at all possible for the additional device support and multiple bug fixes that are included in the later versions.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
JFerello
Justin Ferello
