TMS - which SQL DB premision do in need?
Shy Solenko
Hi ,
I install TMS with all the sql premisions but the IT manager is remove all the premmision exept DB OWNER.
It will work ok with that premmisions only?
Shy
Hi Shy,
As per the TMS Install Guide linked by Dale above, yes, just having the 'dbowner' role for the tmsng database is sufficient (see top of page 8).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
