09-24-2017 11:39 PM - edited 03-18-2019 01:29 PM
I am trying to use the scheduling mailbox feature in TMSXE 5.5 and have 10 ports reserved for video call type on each protocol, however, when I attempt to use that mailbox as a resource in Outlook meeting, I get a response from TMS stating with Subject "Action Required: " and email body containing "Proposed Action: Remove telepresence rooms or call-in participants, or contact your administrator." "Cisco TMS could not schedule the necessary telepresence resources for this meeting. Try rescheduling with a different time or different telepresence rooms, or contact your administrator for assistance."
Do I need to configure anything on TMS (v15.5) too for it to be able to identify this meeting room resource and allocate VC resources?
Solved! Go to Solution.
09-25-2017 10:27 AM
Do you have enough resources for 10 participants on each protocol?
Depending on your deployment, default conferncing settings etc, that could be a lot of resources assumed (TMS will be looking for a bridge that an host all those participants)
Can all of the protocols be routed in the same conference as dial-in calls?
See if you can you make a similar booking manually in TMS
i.e.: add 10 dial-in participants of each protocol (at the same time)
Will TMS schedule the call?
09-25-2017 10:27 AM
09-26-2017 12:34 AM
Thanks Zoltan, it turned out to be silly mistake. I was adding 10 ports for ISDN too which we do not use and that's probably why TMS was complaining that it could not schedule necessary resources.
From your suggestion, I tried creating conference on TMS portal and it threw me error on ISDN connection straight away.
Appreciate your help.
