05-21-2013 06:03 AM - edited 03-18-2019 01:08 AM
TMS 13.2 and TMS PE 1.0 has been working fine for months.
VCS has been on 7.2.2 since it was released.
We just upgraded to 14.2.1 and in attempting to upgrade to TMSPE 1.1, we have received a failure.
As far as I know, there is no uninstaller and the install guide does not cover this. Do I need to use the TMSPE install to uninstall?
Is this going to cause a problem from the TMSPE 1.1 installer since it will not think it is upgrading once TMSPE 1.0 is uninstalled.
Thank you
Solved! Go to Solution.
05-21-2013 07:02 AM
Hi John, I would suggest to perform backup of the TMSPE database in SQL and un-install TMSPE 1.0 and then run windows patch updates to ensure that all critical Windows Updates are installed on your server and verify if you are running
Java 7 update 17, 32-bit or 64-bit as per requirement.
During TMSPE 1.1 installer you can select use existing SQL TMSPE database and proceed with installation.
HTH.
BR, Mahesh Adithiyha
05-21-2013 07:02 AM
HTH.
