TMSPE - Jabber Video - Maximum number of users?
Robert McAffery
Hi Guys,
(a new install)
I have a client that is looking to use AD to add users to Jabber/Movi.  They will be using TMSPE.  They are thinking of rolling out to about 10,000 users.  Does anyone know what the maximum number of Jabber accounts are?
What about hardware/software requirements for the TMS and SQL server?
Robert
Magnus Ohm
This is all mentioned in the TMSPE deployment guide.
http://www.cisco.com/en/US/docs/telepresence/infrastructure/tmspe/install_guide/Cisco_TMSPE_Deployment_Guide_1-0.pdf
"Would cause the VCS to exceed internal table limits"
A Cisco VCS cluster of any size supports the import of:
10,000 users for provisioning
10,000 FindMe accounts
200,000 phonebook entries
1 VCS can support 10 000 users imported but you will only be able to register 2500 of them unless you have a cluster of more VCS's to coat with more registrations.
In total TMSPE can support up to 100 000 users, but to be able to register all of these users at the same time you need a minimum of 40 VCS's .
/Magnus
Magnus Ohm
/Magnus
Thanks! I looking in the guide..... but obviously missesd that.
Cheers!
Rob
