02-26-2014 03:15 PM - edited 03-18-2019 02:39 AM
Is there or could there be a way to specify a default password for imported users in TMSPE? I know you can have TMSPE auto generate random numeric or alphanumeric passwords, but it would be nice if we could specify a default password to start with. There already is an option to not generate passwords, so why not give a third option to use a default one?
Alternatively, could there be a way to make the passwords for TMSPE users a single default password by some sort of SQL script, or the like?
03-03-2014 12:53 PM
There is no supported (or even unsupported) method of using a single default password for imported Jabber users. From a security perspective, that would be very bad. There would be know way of knowing if the user is logging into there own account, or someone else's.
03-03-2014 01:02 PM
Hello Zac -
Very true, security would be bad, yet we have the ability to import users and leave the password blank. It would be nice to be able to provide some sort of default login for imported users (when not using AD authentication), so that they could login to there account without any big issue of not knowing there password without having to ask anyone, until they change it, if they do.
03-03-2014 03:13 PM
This was a big comlaint when we started with movi2, so it must be a long tome ago.
I think its not well handled that there is no way to import users/passwords or an
easy way to change them.
Patrick, do you wonder about JabberVideo or endpoints? At least for JabberVideo
I would recomend to go the NTLM/AD authentication way.
Please remember to rate helpful responses and identify helpful or correct answers.
03-03-2014 03:23 PM
Patrick, do you wonder about JabberVideo or endpoints? At least for JabberVideoI would recomend to go the NTLM/AD authentication way.
Yes, but we have a mix of internal users with AD accounts, and others that are external without any AD accounts that aren't tied to our organization, but we provide them the ability to conference with us. So unless Cisco comes up with a mixed authentication mode for the VCS (local database and NTLM) to allow a good mixed authentication method, we can't go the NTLM route. Some have tried some other wacky domain/subzone config setup on the VCSs from what I've read in the forums, but rather not go that route unless it's idealy simple and secure.
03-04-2014 05:54 AM
As long as TMSPE is cofigured with auto password generation, and a connection to an email server, TMSPE can send emails to the users that would contain what there password would be. Also, with PE, the end user can access the User Portal pages via TMS Portal, and they can change their passwords themselves.
03-04-2014 06:25 AM
Very true, but what if half the users that get imported into PE aren't using Jabber Video.. yet, then you have these emails going about and they woldn't know what they were, they'd think they were spam perhaps.
03-04-2014 06:33 AM
Then don't have the email sent out automatically. Or have the email state that the password is for Jabber usage only. Either way, for Jabber users that need to change their password can use the portal.
03-04-2014 10:29 AM
For me the password handling is really bad, especially with TMSPE and >X7.2.
It should be possible to import passwords, extract all passwords for all users or use an external database
to authenticate on (besides AD), all that does not seem to be possible.
Lets look how it worked before, you could completly ignore the password set by TMS and
simply use an LDAP server with h350 to authenticate these users and it worked for JabberVideo and endpoints
with out any issues.
Now with TMSPE the users are replicated to the VCS incl their unknown auto generated password.
As the local database is poppulated the LDAP authentication will not be asked, and there is no
option to disable this behavior.
So no, order selection of Authentication methods (like only ldap or local) or have a second try
like if failed on local, try ldap.
With the later VCS releases well working things were removed or got broken (see no interop of VCS
versions on traversal zones).
05-27-2014 10:21 AM
Sending passwords in cleartext is BAD and against standard security practice!
What I need is a way to allow my non AD users to reset their Jabber/Movi passwords via web lnk (Like it's done with ciscojabbervideo.com)
