TMSXE Cluster
Georg Kehrer
Level 4
Level 4
Dear all
Does anybody has experience with TMSXE Cluster Configuration
I have the follow Setup:
TMS-1 (active)
TMS-2 (passive)
Load Balancing via F5 for TMS Cluster
TMSXE-1
TMSXE-2 (failure during setup process at the end)
now I have install /setup the TMSXE Cluster Configuration, first Node was successfully configured.
after I started with the second Node Configuration it was possible to read the Configuration and connection the the Exchange but on the last Step I'm getting a error message:
"Unable to store Cluster information in Exchange, verify that no other nodes are running"
Active Node:XX12020 (first TMSXE Node)
---> see screenshot:
Any input or what could be wrong are very appreciated.
Thank you
Best regards
Georg
Georg Kehrer
Level 4
Level 4
Dear all
the release has a Bug if install seocnd Node, the second node will not make the entry in the registry.
it exist a workourund , I have do that togehther with Cisco TAC, we have add manually the Registry entry.
https://tools.cisco.com/bugsearch/bug/CSCux97718
Best Regards
Georg
Did you also use the TMS booking Service Feature for redundancy? I'm looking for the Load Balancer Config for TMSXE and TMS Config.  For the Phone book, we use TMS, Once it is clustered the endpoints need to be update to the Virtual IP of the NLB Correct?
