TMSXE multiple Exchange Servers
Paul Woelfel
Level 4
Level 4
I'm using TMSXE for some time with different installations now, but I know got a question if this could be possible.
Is it possible to connect with TMS XE to different Exchange Domains, meaning running multiple Instances of TMSXE on different Servers? I know one TMSXE Instance only supports one Exchange EWS Url, but if you use different TMSXE Instance, could you sync from different Exchange clusters?
BR Paul
Regards, Paul
Kjetil Ree
This is not a supported configuration – you should have exactly one TMSXE for each TMS.
-Kjetil
Kjetil Ree
-Kjetil
Agreed with Kjetil... It can only support one exchange per TMSXE per TMS.
Thanks.
Saurabh
Thanks Kjetil, i thought that this would be your answer, but I was just currious ;-)
Regards, Paul
Hi Kjetil,
could you clarify which would be the best solution if a Customer have multiple exchange domains and want to integrate all of them with TMSXE?
