TMSXE / SQLExpress on same TMS Server Ok?
thorstenn
Level 4
Level 4
i want to install TMSXE and the local SQL server of the standard TMS Software all on the same Server. Its not a big deployment so i thing its ok.Any concerns or experience if this is fine or will make problems?
Cheers
2 Accepted Solutions
Patrick Sparkman
It should be okay, here are the recommended specs, you'd probably use the standard deployment.
Virtualization for Cisco TelePresence Management Suite
You can also refere to the TMS Install Guide as well.
As Patrick has said, yes, that should be OK, especially for a small deployment.
Saying that, the testing notes in the docwiki link shows that it should support up to 1000 direct managed endpoints, 40 MCUs and provisioning when set up correctly on a Cisco UCS C220 M3S platform, so it's highly likely that it'll work for what you're asking.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Patrick Sparkman
Wayne
Wayne
thorstenn
Level 4
Level 4
Thx guys.
