Touch 10 communication with crestron
rjrahuljain0106
Can anybody let me know how to use Cisco SX80 and touch 10 communication with Crestron 3 series control processor. I am already done with cisco in room control preparing the required GUI and loading it in Touch Panel, is there any further programming required in Cisco.
Anurag Srivastava
Please refer the below link-
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce96/sx-mx-dx-room-kit-customization-guide-ce96.pdf
Please rate if it is helpful...
Wayne DeNardi
This appears to the be same question you asked in another post, just with a different title (https://community.cisco.com/t5/telepresence-and-video/touch-10-communication-with-crestron/m-p/3785296)- perhaps you can remove whichever one is not correct, or rephrase your question(s) to more appropriately describe the issue you are having.
But, despite that, if you are wanting to use the Crestron with the SX80 and In-Room Control, most of your programming effort will be on the Crestron side and getting it to react to the xevents and widgets.  Not much needs to be done on the Cisco end once you have your In-Room Controls set up and functioning on the Touch10.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
