Touch 10 connection thru LAN
RS1601763J2
Trying to make connection to codec thru LAN.  Touch 10 not communication with codec.  Is there any special switch configurations to make so the touch 10 will make the connection.
Vaijanath Sonvane
No special configuration is required on the switch. Please verify that:
  • Switch ports connected to Touch 10 and Codec are configured with correct VLAN.
  • Touch 10 and Codec are getting correct IP Address, Subnet and Default Gateway
  • Touch 10 and Codec are able to Ping each other.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Anurag Srivastava1
Please also tell about which codec you are using and what is the software version of that?
Please rate if it is helpful and mark as accepted solution if applicable..
Please rate if it is helpful and mark as accepted solution if applicable....
