12-17-2015 07:54 AM - edited 03-18-2019 05:19 AM
Some one can answer me what is the name of the cable that uses to connect a TP SX 80 to a Touch10? and where can I get one and the length available? Or correct me if I'm wrong, PoE rated Ethernet cable?
12-17-2015 09:47 AM
Any cat5e cable should do fine. I don't know the length, never rolled one out long enough to find out. Not sure they can be ordered separate of the Touch 10, at least I don't see a part number specifically for it. Do you have a Touch 10 that never came with a cable, or have a broken cable?
12-17-2015 10:00 AM
