Touch 10
j.philip1
Some one can answer me what is the name of the cable that uses to connect a TP SX 80 to a Touch10? and where can I get one and the length available? Or correct me if I'm wrong, PoE rated Ethernet cable?
Patrick Sparkman
Any cat5e cable should do fine. I don't know the length, never rolled one out long enough to find out.  Not sure they can be ordered separate of the Touch 10, at least I don't see a part number specifically for it.  Do you have a Touch 10 that never came with a cable, or have a broken cable?
The original cable installed was only 10' and lined to move this from its originally planned location.
I found the extension cable and could not confirm with anyone this will work or not! Attached is the pict i think do the work.
