Touch Screen disable Settings
philokoi0
On the TC5.1 Touch Screen for C20 or EX90, is there a way to disable acces to the "Language, Camera Control & Setttings, Display Settings and Ringtone & Sound Settings"?
This to avoid any problem of mis use by customers.
I don't find any command in the admin guide to disable this.
Thanks for your answer,
Philippe
Teck Chye Tang
Unfortunately, this is not possible.
OK, thank you for your quick answer
