12-16-2017 07:18 PM - edited 03-18-2019 01:41 PM
we are using Cisco SX80 [TC 7.3.6 ] with Touch 10.
Is there any default username and password for Touch 10 ?
or any password recovery possible, if by mistake , user has forgot the credentials.
Please advise.
regds,
aman
Solved! Go to Solution.
12-16-2017 09:54 PM
12-16-2017 09:54 PM
12-17-2017 07:00 AM
thanks a lot Patrick.
I will check tomorrow and revert.
regds,
aman
12-21-2017 04:17 AM
Problem Solved. thanks a lot Patrick.
Tried SX80 username and password on Touch 10 and it is working.
regds,
aman
09-17-2020 01:37 AM
Hi All,
My question is, after resetting the password to the default settings, do you loose as well you setting i mean you own configuration for example network settings, time settings, etc etc or not?
Kind Regards,
Tahar
09-17-2020 07:47 AM
You can't reset just the password, the process described above is resetting the device to factory defaults, so the configuration would be affected.
A factory reset implies:
• Call logs are deleted.
• Passphrases are reset to default.
• All system parameters are reset to default values.
• All files that have been uploaded to the system are deleted. This includes, but is not limited to, custom wallpaper, certificates, and favorites lists.
• The previous (inactive) software image is deleted.
• Option keys are not affected.
The video system restarts automatically after the factory reset. It is using the same software image as before.
