Touchpanel 10 looses network data
andreas.baur.external
Community Member
all,
has anyone already experienced a loss of network configuration on Touchpanel 10 connected to SX20N running running ce 8.2.2 after panel is disconnected from network / power?
Any experiences made so far?
regards
andy
PJMack
Level 11
Level 11
Are you using the flat cable that comes with the codec to connect the Touch 10 to the network? I have personally seen a number of those fail, they are quite fragile from my experience. Try replacing it with a standard CAT5/6 cable.
Once the Touch 10 has been paired to a codec you should be able to survive a reboot no problem, that's why I am guessing it might be your network connection, but if that doesn't do it please provide more information, what codec are you pairing it to, what SW rev is running, etc.
