06-22-2018 05:21 AM - edited 03-18-2019 02:11 PM
So can a couple of old Tandberg TTC8-01 be used for anything? They have HDMI outputs on it and power supplies are not a problem.
Just seems like such a colossal waste to toss/excess them given the optics are probably just as good as the newer CISCO codec cameras.
Solved! Go to Solution.
06-22-2018 06:00 AM
They are only 720p, not 4K like the newer ones, so they are not nearly the equal of new ones. You also can't control them without a serial connection (the later 12x cameras could be controlled independent of the codec with a Tandberg remote).
IMHO they are throwaway at this point unless you have a specific use case for them. You could try selling them but I doubt you'll find any buyers for a 12+ year old camera.
06-22-2018 06:00 AM
06-27-2018 09:54 AM
