Traversal call license usage on a Cisco VCS
SupportAC
Hi guys,
I have a customer with VCS and VCS-e x7.2.They receive many call frauda attemps that are prevented with block search rules .
But the customer is discover that when call fraud hit VSC-e even with block search rules the box consume traversal license for less a second.
My question is , VCS-e has a mechanism for prevent that?  I read about CPL/ find me service but im not 100% sure.
Many thanks
Carlos
9 Replies 9
Chris Swinney
Level 5
Level 5
Hi Carlos,
I assume you are talking about SIP Spam attempts? If so, CPL (Call Policy) may well help is this is check first by the VCS. There are a number of threads on here regarding this an I believe there may even be a document posted that might help.
Cheers
Chris
Hi Chris,
Thanks for your reply.  Yes the fraud call are SIP spam attemps .
So if a  implement CPL i prevent VCS-E to send query to VCS-C? that ritght?
Carlos
Indeed, as Marting says, If just a search is conducted then no call licence should be used until a endpoint is found and a call is placed. If the search blocks the lookup, then no call licence should be used.
However, using a simply CPL doesn hurt. SOmething like:
Source pattern:  (leave blank)
Destination pattern: .*@IP_Address_of_VCSE
Action: Reject
Then
Source pattern:  .*
Action: Allow
You could alway ensure that SIP UDP is OFFas well (unless you want it on for a specific reason).
Cheers
Chris
Hi Chris,
Thanks for your reply. Please see the attachment that i provied you.
First screeshoot you is a check pattern test , the tould fraud calls destination is matched
00972597751891@93.190.152.15
but on the call history " Second screenshoot " you see the 480 temporarly not available and  call duration of 1 second
The issue with creating a pattern more generic is that i can block non fraud call .
Carlos
Hi!
There is no screenshot attached.
It would be interesting to see the full search details (of all call legs) and of both VCSs (if it hits your second VCS-C).
Hi Martin ,
He the logs from VCS-e and C   plus a locate :
VCS-e :
Call details
You are here: Status Calls Calls Call details
Call information
State
Connection Failed
Start time
2014-04-02 17:03:05
End time
2014-04-02 17:03:06
Duration
1 second
Tag
e4f792b0-ba77-11e3-9513-0010f320813c
Serial number
e4f790f8-ba77-11e3-a6b3-0010f320813c
Bandwidth
Requested
1152 kbps
Allocated
1152 kbps
Route
DefaultZone -> TraversalSZtoDefaultZ -> TraversalSubZone -> Zone001ToTraversalSZ -> TZtoVCSControl
Leg 1
Bandwidth node
Default Zone
Source alias 1
sip:50011@x.190.x.x  (Url)
Target alias 1
sip:+00972592652763@x.190.x.x (Url)
Protocol
SIP
Address
95.211.89.233:5078
Transport
UDP
Reason
Not found
Cause
404
Leg 2
Bandwidth node
TZtoVCSControl
Target alias 1
sip:+00972592652763@93.190.152.15 (Url)
Protocol
SIP
Address
10.42.19.11:25067
Transport
TLS
Encryption type
None
Leg 3
Bandwidth node
TZtoVCSControl
Target alias 1
do-not-route-this-call (H323Id)
Protocol
H323
Address
10.42.19.11:1719
Reason
Not registered
Cause
Destination not found
Session 1
Status
Failed
Media routed
True
Call routed
True
Participant 1
Leg 1
Participant 2
Leg 2
Bandwidth allocated
1152 kbps
Bandwidth requested
1152 kbps
Route
Session 2
Status
Failed
Media routed
True
Call routed
True
Participant 1
Leg 1
Participant 2
Leg 3
Bandwidth allocated
1152 kbps
Bandwidth requested
1152 kbps
Route
VCS-C :
Call details
Call information
State
Connection Failed
Start time
2014-04-02 17:03:05
End time
2014-04-02 17:03:05
Duration
0 seconds
Tag
Serial number
e4fb3ad2-ba77-11e3-98f0-0010f31ed7ac
Bandwidth
Requested
1152 kbps
Allocated
1152 kbps
Route
TZtoVCSEW -> VCSeToTraversalSZ -> TraversalSubZone -> NZoneMexicoToTraversalSZ -> NZoneMexico
Leg 1
Bandwidth node
TZtoVCSEW
Source alias 1
Target alias 1
sip:do-not-route-this-call (Url)
Protocol
SIP
Address
93.190.152.15:7001
Transport
TLS
Encryption type
None
Reason
Not found
Cause
404
Leg 2
Bandwidth node
NZoneMexico
Target alias 1
Protocol
H323
Address
10.26.5.202:1719
Reason
Not registered
Session 1
Status
Failed
Media routed
True
Call routed
True
Participant 1
Leg 1
Participant 2
Leg 2
Bandwidth allocated
1152 kbps
Bandwidth requested
1152 kbps
Route
LOCATE :
Search completed.
  • Search (8)
    • State: Completed
    • Found: False
    • Reason: Not Found
    • Info: Policy Response
    • Type: SIP (OPTIONS)
    • CallSerial Number: 3bf11952-ba7c-11e3-97b4-0010f320813c
    • Tag: 3bf11af6-ba7c-11e3-9060-0010f320813c
    • Source (1)
      • Authenticated: True
      • Aliases (1)
      • Alias (1)
      • Type: Url
      • Origin: Unknown
      • Value: 50011@x.190.x.x
      • Zone (1)
      • Name: TZtoVCSControl
      • Type: TraversalServer
      • Path (1)
      • Hop (1)
      • Address: 127.0.0.1
    • Destination (1)
      • Alias (1)
      • Type: Url
      • Origin: Unknown
      • Value: sip:+00972592652763@x.190.x.x
    • StartTime: 2014-04-02 17:34:09
    • Duration: 0.39
    • SubSearch (1)
      • Type: Transforms
      • Action: Transformed
      • ResultAlias (1)
      • Type: H323Id
      • Origin: Unknown
      • Value: +00972592652763@cemex.com
      • SubSearch (1)
      • Type: Admin Policy
      • Action: Proxy
      • ResultAlias (1)
      • Type: H323Id
      • Origin: Unknown
      • SubSearch (1)
      • Type: FindMe
      • Action: Proxy
      • ResultAlias (1)
    • Type: H323Id
  • Origin: Unknown
  • SubSearch (1)
  • Type: Search Rules
  • SearchRule (1)
  • Name: Block Incoming calls with +
  • Zone (1)
  • Protocol: SIP
  • Found: False
  • Reason: Not Found
  • Duration: 0.19
  • Gatekeeper (1)
  • Address: 10.42.19.11:25067
  • Alias (1)
  • Type: H323Id
  • Origin: Unknown
  • Value: do-not-route-this-call
  • Zone (2)
  • Protocol: H323
  • Found: False
  • Reason: Not registered - Destination not found
  • Duration: 0.18
  • Gatekeeper (1)
  • Address: 10.42.19.11:1719
  • Alias (1)
  • Type: H323Id
  • Origin: Unknown
PD : Now you can see the sreenshoots?
Carlos
Hi Carlos,
To my mind, this is a funny way of doing things.
I would set up a local Call Policy at the VCS-E using the rule mentioned above.
Or switch OFF SIP UDP at the VCS-E unless you have a reason to use it. In new installs (not upgrades) of the VCS (x8.1), SIP UDP is switch off by default, but I still like to have some CPL rules in place.
Chris
Martin Koch
Hmmm, how and where do you see that call license being used?
I just tried it. Rebooted my lab VCS to reset the call counter,
dialed into the VCS with and invalid URI and the counter is still 0 and the call history
shows me a 404.
Sure that you do not have a call loop or some alias being hit somewhere?
Do you have your search and call history and logs?
Hi Martin,
Thanks for yor reply and your effort .
The first question :
how and where do you see that call license being used? That information was provided by customer, I suppose that he check that status of VCS.E.
Im sure that call is not hit somewhere , regarding loop i suppose that i need to have the same search rule pointing from VCS-C to VCS-E? right?
