Trending peak/capacity of MCUs
ROGER MCGUIRE
Other than manually looking at the MCUs everyday and manually documenting what is seen, is anyone aware of an automated way to collect peak MCU usuage as far as # of calls/connections on the MCU?   Like any SNMP MIB variables that can be polled?   3rd party apps?   Any other ideas?
Thanks in advance
Magnus Ohm
TMS collects call history from the mcu and you can use the reporting in tms for a specific day or month/year to see the utilization trends.
Or are you looking for something else?
/Magnus
