03-28-2024 08:12 AM
Is the CAB-MIC20-EXT compatible with CS-CODEC-EQ- K9+?
04-05-2024 06:36 AM
It's just a an extension cable. Why should i be not compatible?
04-16-2024 10:35 PM
It's a 4-pole 3.5mm jack extension cable, so it should work as it's just a straight through cable connecting the 4 pins at each end.
There may be internal impedance differences between that and the recommended one which could cause you issues down the track.
The "correct" part to use is the CAB-MIC-TABLE-J=
Please remember to mark helpful responses and to set your question as answered if appropriate.
