01-14-2016 08:23 PM - edited 03-18-2019 05:26 AM
Hello all,
We have recently purchased a few Cisco MX300 G2 endpoints (registered to VCS). The endpoints are running TC7.3.4.e4daf54 software version. The question I have is in regards to turning off the 'Call Rate' settings from the user interface while dialing . I have looked all over an am unable to find an answer to this. I basically want to lock it down without giving the user an option to change Call rates etc.
Any one have any ideas/help!?
Thanks all
Navin
Solved! Go to Solution.
01-15-2016 06:42 AM
You can only set the default call rate that new calls will use, it's not possible to lock the call rate to a specific setting and prevent it from being changeable if the user wants to.
If this is a feature you'd like to have, suggest you contact your Account Manager, they can create a feature request for you.
01-18-2016 02:26 PM
The option itself cannot be removed but can be limited, you can set the "MaxTransmitCallRate" to the highest you want to allow them to use. this setting is only configurable by an administrator so you would have to give them user accounts and set this to the maximum you want to allow them to use.
When doing this, even if going to dial on the touch panel and trying to manually set the call rate, I will only allow to select the rate configured under "MaxTransmitCallRate" or lower.
As Patrick stated, if you are specifically looking to get that option removed, you will have to reach out to your account manager and have a product enhancement request filed.
Keep in mind I tested the above on a different version and a later version of TC software so it might change depending on your software version but TC behaves mostly the same across endpoints.
01-15-2016 06:42 AM
01-18-2016 02:26 PM
01-18-2016 02:29 PM
Hi Patrick / Randy,
Thanks for your responses. I am aware of how to limit the max transmit on the call from the admin pages however my main concern was with the minimum call rate - Audio. I don't think this can be turned off ?. Either ways I guess you both have answered my question
Navin
01-18-2016 02:33 PM
Understood, unfortunately there isn't a minimum call rate limit, the setting was designed to avoid overloading the network so there hasn't really been a need to have a minimum limit
