Tx9200 configuration requirements
Bo Bo Aung
Dear All,
May I know the following question for tx9200 configuration.
What is the network requirements?
How many IP needed?
Configuration requirements for CUCM?
Thanks and Regards
Bo Bo
Marius Nedregaard
Hi.
You can find all the physicall information on this link:
http://www.cisco.com/en/US/docs/telepresence/tx9000/assembly_guide/tx9000_room_recommendations.html#wp1163533
CUCM requirements can be found at
http://www.cisco.com/en/US/docs/telepresence/cts_admin/1_9/compatibility/cts_compatibility_1_9.html
10mbps is required for this System.
How many IP needed?
1 IP/network port for this system. If you want network connectivity on the tables, you need additional network ports.
You need at least CUCM 8.5.1 to run 1.9.x CTS software. Configuration will be as easy as the rest of your telepresence equipment.
//Marius
Hi Marius
Thank you so much for quick respond.
Best Regards
Bo Bo
