jeffzigcisco
Patrick Sparkman
You're seeing the alias because the external endpoint has either an E.164 address or H323 ID configured.  There isn't a way to change how the information is displayed, you're only option is to go into the call details or the event logs on the VCS to see the source IP of the endpoint.
If you can import XML, you could get the CDR data from https://vcs_address/history.xml.
